Scrambler pulling to the right & hard to steer left!
Old Nov 21, 2006 | 10:03 PM
01vic99's Avatar
Default Scrambler pulling to the right & hard to steer left!
mine did something similar when i stripped out one of the rear hubs. i stripped out the right one and the left one pushed me to the right. when i jammed on the brakes only the left was grabbing so it would pull left when stopping. something very simple to check on.
Old Nov 21, 2006 | 10:34 PM
scramblerXrated's Avatar
inspect the brakes first. then the tierods. then the ball joints.
if the brakes are dragging, try bleeding them real good all around.
X
Old Nov 22, 2006 | 04:29 AM
scrammersam's Avatar
bearings?
Old Nov 22, 2006 | 06:48 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
its your hub
Old Nov 27, 2006 | 11:26 AM
  #15
NVMYZ28's Avatar
Its your 4 wheel drive hubs not disengaging or not fully engaging in the front (depending if you are in 4 wheel drive or not). They are disengaged enough to not turn the wheel, but engaged enough to cause it to drag.....
It happens regularly to me if I dont change the hub fluid often.
Change your front hub fluid, and change it often. I run mobil 1 synthetic ATF in mine, and change it about every other ride. It gets dirty really quick since there is so little of it - but keeping it clean keeps the hubs functioning properly. Synthetic helps that much more - and its more tolerant of heat.
The hub fluid is CAKE to change.
toonces
Oct 16, 2019 12:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Scottma518
Jul 10, 2015 12:42 AM
sara durrant
Jul 6, 2015 05:32 PM
traumajunkie
Jul 5, 2015 03:03 PM
