Tie down ?
Old Nov 23, 2006 | 08:53 PM
POLTAB's Avatar
Default Tie down ?
Is it ok to use the front winch to secure my X2 to the trailor? Any advice?
Thanks in advance.
Old Nov 23, 2006 | 10:03 PM
Default Tie down ?
I've used it since I got my X2 and haven't seen anything like kinks develop in the line. I usually spool it in to the point the hook is pivoting off the rollers on the fairlead and pull the hook straight down. It is a better anchor point than the metal bar in the center under the radiator. I don't think it harms the winch at all.
Old Nov 23, 2006 | 10:35 PM
POLTAB's Avatar
Default Tie down ?
Thanks Moose
Old Nov 24, 2006 | 01:18 AM
scrammersam's Avatar
Default Tie down ?
i wouldnt rely on just the winch
Old Nov 24, 2006 | 11:55 AM
JCDEYO25's Avatar
Default Tie down ?
I use 4 heavy duty ratchet straps.....One on each corner.......I agree with not just depending on the winch for a solid tiedown......
John
Old Nov 24, 2006 | 12:14 PM
POLTAB's Avatar
Default Tie down ?
Sorry I did not mention that I have 2 ratchet ties for thr rear. Thanks
Old Nov 24, 2006 | 05:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Tie down ?
ive use my winch as the only tie down for the front for yrs w/ no problems but i always put 1 or 2 strapps on back depending in where i go.
Old Nov 24, 2006 | 09:56 PM
20045SP500HO's Avatar
Default Tie down ?
The winch is a bad idea ... unless it has a manual brake, they can and will loosen up over time and not hold tight during towing.
One strap in the front and two of the rear, should be the minumin ... I use two front and two rear, don't want to lose and $8000.00 machine over $50.00 is straps.
Old Nov 24, 2006 | 11:55 PM
sheepdogMSP8117's Avatar
Default Tie down ?
Why risk the cost of a winch in using it for a purpose it clearly wasn't intended for? I use ratcheting tie-downs front and rear. At $15 new, I'd rather buy a new set each year than risk breaking my $500 winch. Or like someone else said, lose the ATV.
Old Nov 25, 2006 | 03:04 AM
Lukester's Avatar
Default Tie down ?
The rear ties will keep it from slamming forward. You may be relying on the winch to keep it from sliding backwards but I wouldn't rely on it alone.
