sportsman HELP!
putting the motor back in the quad and i have a brass barb fitting in the cylinder head, just in front of where the intake bolts up for the carb. it sticks strait up towards the fuel tank.
i have no idea what was hooked up here.
it shows a pic of it in my manual, but no mention of anything.
thanks!
thanks!
Originally posted by: SAshton
Is it the intake filter hose.(it goes from the vavle cover to the left side of the air box with a filter in between the hoses)
this is a barb molded right into the cylinder head.
thanks!
Originally posted by: stendori
is it a electrical plug?
it is a brass hose barb. 1/8" or so. sticks right out the top of the head. its actually in line with the valve cover breather hose.
i have no idea what goes here.
i had all my atv parts in one box when i tore it apart, and dont have a hose to go back on it. puzzles me.
dealer doesnt know either, but they dont know much of anything.
if i had the intake unbolted from the head, you could prolly stick your fingers in the head port and feel the hole, id guess.
thanks.
ok, ive got everything buttoned up and still have this barb sticking out the top of the cylinder head.
even the dealer here or breese lawn and garden doesnt know what its for.
I DO HOWEVER have a fuel line from the fuel pump that is not hooked up.
could this be a vent to get rid of fuel vapors into the engine?
hose looks like it might have went there before, but im skeptical to put it there in fear of locking up the motor with fuel.
i guess i should just crank it up with it off and see if fuel spits out the hose.
any reccomendations?
thanks!
thanks!
I don't have much experience with a 700 but this sounds like an engine vent. There should be a hose going from the air box to the vent.
If it is in the intake tract it will be the sorce of vacum for the fuel pump.
figured it out before reading this post, but THANK YOU!!!!!
finally found out that the P on the pump was for PULSE. should run tomorrow or saturday.
waiting on a front cv axle and ill be good to get muddy.
thanks again!!!
thanks again!!!
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
