98 Trail Blazer Tranny Noise
Old Jan 3, 2007 | 08:46 AM
mtnxtreme800's Avatar
Default 98 Trail Blazer Tranny Noise
My 98 Trail Blazer makes a skipping/ grinding noise when you hit the throttle under load and won't move forward, if you walk alongside it it will not do it. Sounds like the tranny, was wondering if this sounds familiar to anyone. I guess I gotta pull the tranny, don't have my shop manual yet, so I was also wondering if I need to know anything about splitting the tranny, should I pull off one side over the other, are a million pieces gonna fall out on me, is there anything in there that is known to do this, maybe the chain??
Old Jan 3, 2007 | 02:42 PM
scrammersam's Avatar
maybe your shifter linkage needs adjusting
Old Jan 4, 2007 | 01:22 AM
I def gotta check that, I did pull the tranny tonight . the guts all look good except the chain is real loose, I'm thinkin thats the problem.
Old Jan 4, 2007 | 02:05 AM
STARKSREBEL's Avatar
if the chain is real loose it will slip under hard exceleration.be sure to check the teeth on the gears for wear and foward rolling.also check thebrake disc for loosness or loose brake shoes.
Old Jan 15, 2007 | 04:51 PM
Update, it was the chain, gears were OK, it was stretched not broke, this tranny has no idler/ tensioner, which I think some do, and would have taken up slack as it was minimal, so $41 later I'm good to go, and even better yet, I got the quad for $400, so it ws a chance that turned into a score!
Old Jan 15, 2007 | 06:47 PM
ftwflh's Avatar
Take a close look at the shift forks while you have it apart and if they have any wear at all go ahead and replace.
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
D-Hagz
Jul 4, 2015 02:19 AM
