4x4 working part 2
Old Jan 14, 2007 | 01:41 PM
Bukrub66's Avatar
Default 4x4 working part 2
I took my xplorer out for the first time just to play. I tried to cross a creek thinking this thing would just climb right thru it, but it didnt. Put it in reverse, and there I was stuck. Ended up useing a come along. Anyway, Im sure alot of it had to do with tires, but as I sat there spinning, all of the tires were spinning except the left front. Should all the tires lock in and spin or is this normal? Is there a way to test if the 4x4 is working properly? I was going to put it up on jack stands to see if they all spun, but figured I best ask someone smarter than me first.
Thanks Buk
Old Jan 14, 2007 | 02:50 PM
v2rider's Avatar
Thats normal. You have a "three wheel drive"[img]i/expressions/face-icon-small-happy.gif[/img] Thats where a locking diff comes in nice[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 14, 2007 | 03:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
last time i knew it was a AWD not a 3 wheel drive. all wheels spin.
Old Jan 14, 2007 | 06:24 PM
Heinz01's Avatar
Your right stendori,"AWD" means all wheel drive, period. Check the wires going to the coil. And check the fluid in the hub. Check about 3 or 9 oclock position. Plate in hub might be worn out also.
Old Jan 14, 2007 | 07:20 PM
v2rider's Avatar
Its a 97 explorer. Hes never going to have power to all four wheels at once. If you can some how stop the front wheel thats spinning, the other one will spin.
Old Jan 14, 2007 | 07:40 PM
Heinz01's Avatar
Wow that wierd because I have a '95 magnum, and they all lock in. Might want to recheck your notes, V2 rider
Old Jan 14, 2007 | 08:17 PM
Bukrub66's Avatar
I found the wires are broken at the front right wheel. Can I just tie them back together, or do I need to replace something. I read in the book about ohm readings, so I didnt want to mess anything up.
Old Jan 14, 2007 | 08:28 PM
v2rider's Avatar
So you have a locked front end all the time? I was trying to say, it will transfer power back and forth. Thats why i said to stop the spinning wheel, and the other one would take over
Old Jan 14, 2007 | 10:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they both spin all the time in there able to spin. if 1 is getting traction the other will spin at the same speed. i would think you can just reconnect the wires to fix it.
3quadbob
Sep 18, 2016 09:46 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
regrss
Jun 26, 2015 02:59 AM
wildbill59
May 28, 2015 12:05 PM
