U joint replacement on prop shaft
Old Jan 30, 2007 | 10:57 PM
1tonchev's Avatar
Default U joint replacement on prop shaft
I am working on a 1997 sportsman 500, and I noticed the rear u joint on the front prop shaft is real loose and worn.
Is this a replaceable part, or do I need to replace the whole shaft.
Also, how does it disconnect from the output shaft of the transmission. It appears to just be splined and should slide off, but I don't think the previous owner ever greased it and now it is rusted & won't budge. I have been soaking it with a penetrating oil to help loosen.
Thanks in advance.
Old Jan 30, 2007 | 11:18 PM
ricknzep's Avatar
The front of the shaft has a drift pin you have to knock out with a punch, the rear is just splined-you'll have to work at it.
Old Jan 30, 2007 | 11:25 PM
GarryESE's Avatar
U-Joints are replacable.
The tranny output end is splined. Usually if they are not greased they wear out the splines and slip.
Old Jan 30, 2007 | 11:32 PM
ricknzep's Avatar
About the joint itself-check the microfiche part lists on a website like ronayers.com to see if they are available separately-listed with separate part #.
Old Jan 30, 2007 | 11:44 PM
03scrambler500's Avatar
if you want to you can go to napa and tell them you want u joint part# 338 and it is identical to the polaris one and only cost $10 while the polaris one costs 30$ I have replaced quite a few of these
Jason
Old Jan 31, 2007 | 12:15 AM
1tonchev's Avatar
Thanks, I had sweat running down my face, but I got it off. This thing hadn't seen grease in years. It took a torch, a 2 pound hammer and beating the dog snot out of it, but it finally broke loose.
Old Jan 31, 2007 | 01:05 AM
jta4455's Avatar
You probably paid for 3 ten dollar ujoints when you could have bought one for 30 and it would last 3 times longer than the napa brand [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 31, 2007 | 09:12 AM
the napa (precisionon) ones are IDENTICAL, same number of needle bearings, same markings, and the same numbers on the caps i really don't think that polaris makes their own u-joints do you?
Jason
Old Jan 31, 2007 | 03:47 PM
cornbread2's Avatar
The Napa u-joints are as good as the origional. I use them all the time and they hold up well.
toonces
Jul 28, 2015 01:58 PM
carolinabomb
Jul 26, 2015 08:40 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
tporath
Jul 11, 2015 12:31 PM
