Polaris On Demand all wheel drive: how does it work?
Old Feb 19, 2007 | 02:09 AM
  #21
hc's Avatar
hc
Default Polaris On Demand all wheel drive: how does it work?
Hope this helps in understanding the Polaris AWD system:
When AWD is selected in a forward gear, current flows through a coil of wire located in the strut housing, creating a magnetic field. An armature plate coupled to the roller cage is attracted to the magnetic field, and resists rotation, creating drag on the drive roller cage assembly. This causes the roller to climb the ramps of the cam, engaging the hub. Note: In reverse gear the override button must be pushed to deliver power to the wheel coil. With the Polaris All Wheel Drive System activated (AWD selected), the machine operates as a 2-wheel drive vehicle until the rear wheels loose traction. If the rear wheels loose traction the front wheel rotational speed will decrease, causing the front drive axle speed to exceed front wheel speed. Restricting the rotation of the drive clutch of the roller cage will cause the rollers to climb the ramps of the cam, and become squeezed between the ramps and the ring in the hub. When the hub clutch assembly, wheel hub, and drive axle are engaged, the front wheels will drive and engaged until rear wheel traction is regained. When traction is regained, the front wheels will overdrive the hub clutch, pushing the clutch rollers toward the lower part of the cam, disengaging the clutch. The rollers are held in place by the spring. The tension of this spring is critical to AWD hub operation.
Old Feb 19, 2007 | 02:16 AM
  #22
TLC's Avatar
TLC
My God ,thats more than I wanted to know.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 19, 2007 | 11:45 AM
  #23
00XJ's Avatar
Sounds kind of like a Sprag clutch.
Old Feb 19, 2007 | 10:44 PM
  #24
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Hey hc in Alabama...........Great reply.........But do you know why my Sportsman 450 shuts off when I turn my headlights on!!!!!!!!!!.......Caper..........
Old Feb 19, 2007 | 11:18 PM
  #25
SCRAMMYTODD's Avatar
Originally posted by: 00XJ
Thats cause it is a sprag clutch lol
Old Feb 20, 2007 | 12:18 AM
  #26
RticKwad's Avatar
Runs Stealth!
TLC -
What I noticed was my rear sinking
digging further in the mud. I guess
that was spinning? I don't know but
my front never dug in to the more dry
solid ground. This mud was very thick
though and my quad was slanted almost on
45 degree angle is how sunk I was.
Maybe it was just not enough horse
power for the front to pull me out?
I don't have to further analyze I do
accept that reality. (I want a 700cc or
higher but can't justify. Whats the
saying No replacement for displacement,
..aka Stendori) Who knows after I upg
my tire size and type this year I go
back for that challenge. eheh at least
FUN trying!
R'
Old Feb 20, 2007 | 01:45 AM
  #27
TLC's Avatar
TLC
Originally posted by: RticKwad
TLC -
FUN trying!
R'
So your fronts did not turn at all? or they turned but you where still stuck? Thats what I like about low range you have all the pulling power you need without even without a big motor.
A 350cc with low range has more pulling power than a 500cc in high range. A 450 in (low range) will turn the wheels or break something tying,but not run out of power.
Old Feb 20, 2007 | 07:54 PM
  #28
hc's Avatar
hc
Sorry Caper, can't be much help on that one. Obviously it's an electrial problem and sometimes those can be hard to find. Sorry.
Old Feb 20, 2007 | 08:04 PM
  #29
Thanks anyway....I think it is a E.C.M. The dealer thinks that .........Only 7 months of use......Not bad I guess one every year at $130.00 is not too much to ask for.....Polaris keep the 6 M warranty YOUR DEALERS CAN MAKE MORE MONEY THAT WAY!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 20, 2007 | 09:08 PM
  #30
dthack1881's Avatar
I have had problems with the front diff on my bike(03 sp 500 )the steering would jerk left like it was having problems supplying power to the front wheels.....I read on this forum that alot of people leave their bikes in awd all the time and avoid this problem...I tried it And i too have know more problems and it handles like a champ!
MikeyBoyesq
Nov 27, 2020 02:44 PM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
txkevin
Sep 21, 2015 02:02 PM
cornermike
Jun 3, 2015 07:27 AM
Steven Bandemer
May 27, 2015 07:39 PM
