Some questions about 2000' 335 sportsman
Hello All ,
I inherited this atv and have some questions about it.
1st - What is the reverse override and what is it used for ?
2nd - what is the hi/low switch on the left side of the intrument cluster for ?
3rd - what fluid types do I need for the tranny , engine , and radiator ?
override is for when its in reverse. by pushing it it will let you go as fast backwards as forward and also you need to push it in while in revese for the awd to work. this is only in reverese that you need to push it for awd. hi/low is for the headlights. just like a car low/and high beam lights. i would reccomend downloading a owners manual off the polaris web site to tell you diff. fluids to use. the engine should be 0-40 synthic, the rad has polaris 60/40 pre mix and not sure w/out looking on the trans oil.
