winch mounted on 500 scrambler 4x4?
67cam,
can you elaborate on how you fit that winch in there, i get the feeling from my measurements none of the winces will fit. although i see your pics adn it sure does! i would prefer to use a bolt on custom plate method, i dont really want to weld if i dont have to. am leaning toward a gorilla thats a bit cheaper since i wont be using the mount the xtreme comes with.
#15
i did have to do some cutting and welding. what i did was cut the two brackets off the top of the bumper that mount it to the frame, and extended the bumper about 2inches with some pipe. then i welded the brackets back on, and welded the winch mounting plate to the inside of the bumper. sanded it all down put a little bondo on were i entended the bumber and painted it.
exmotocrosser
09-13-2019 06:12 AM
