Hot ? Check Engine ? Help, Help
Old Apr 11, 2007 | 07:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Hot ? Check Engine ? Help, Help
thats good news. that little box is a troubled little piece of crap. it messed up on capers bike and caused it to shut off while turning on the lights. weird!
Old Apr 12, 2007 | 02:14 AM
houser444's Avatar
Ya thats actually the problem i noticed first before the hot light thing. When I had the headlights on the key switch wouldn,t work. I would turn the key on and nothing would happen. turn the lights off and everything worked again. Thats why I started off by charging the battery overnight to see if that cured the problem.
Another unrelated problem I had with the wheeler when I first go it, it was way under powered. I was considering putting a 500 ho cam in to boost the power a little. When I took the cowel and tank off to survey the extent of my cam project I foung the spark plug wire was pincher flat between the tank and frame. The spark Must have been partially shorting to ground kuz now it runs great still on the stock cam. I just put a few wraps of black 88 around the flat spot and rerouted it a little so it wouldn,t be pinched.
MIKE
SOLOLUCKY
Oct 4, 2024 09:09 PM
tweeder
Jul 5, 2015 01:57 PM
bikedad3
Jul 2, 2015 02:15 AM
Trxoutlawz
Mar 2, 2001 09:33 AM
in2atvn
Sep 20, 2000 04:58 AM
