Xplorer 400 Coolant in cylinder
Old Apr 28, 2007 | 04:19 PM
gnadz's Avatar
Default Xplorer 400 Coolant in cylinder
My Xplorer 400 won't run due to coolant mixing in the cylinder. I removed head and jug to pressure check on bench - no leaks and no visible cracks. Head gasket looked fine. I pressurized the cooling system and looked into the crankcase - no leaks. Am I crazy? Where is this coolant coming from? Any common issues to help me guess??? Do some leaks on these only occur when hot? Can the water pump leak into the chamber? I'm drawing a blank on this one.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Dewhound
Apr 20, 2017 02:25 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
