98 Scrambler Tires "Wacha Runnin? "
Old May 4, 2007 | 02:24 AM
eli98's Avatar
Default 98 Scrambler Tires "Wacha Runnin? "
As for height, I would stick with stock. If you change the size of your tires you will need to change your clutching, and or gearing, or you will probably be disappointed with the performance of your quad. Also, we've had about an inch of rain here the last couple of days and not sure I can accurately test the slide of my tires (although I'm going to ride the s#!t out of the mud!!!) but once it dries up around here I will test them if you haven't bought new skins yet.
Old May 4, 2007 | 08:32 AM
Scrambler00's Avatar
i have mudlites on mine and it will slide but i run em at a slightly higher psi, they are great tires and they are cheaper than the stock ones .
Old May 4, 2007 | 01:52 PM
XpLo400's Avatar
get the maxxis irazr 20 ' rear and 21' front.they are the perfect tire for a scrambler if you ride it like a sport quad.They wear fast,the rubber is soft but they do pretty good in mud compared to regular razr.I had them on my 500 and i liked them alot.They are expensive and they wear fast but verry good tires.If you dont ride on pavement alot then they will last alot longer.
fordfaithful21
Dec 7, 2015 05:52 PM
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
maxjung
Jul 13, 2015 05:11 PM
