Trail boss bogs down at hi rmp
I have a trail boss 250 that bogs down when ever I raise the rpms. It sounds like a fuel problem, but it's getting enough and I've cleaned the carb 5 times, tried different float adjustments, needle adjustments, and everything else that I could think of.
Any suggestions?? 110psi compression..
I have the same machine and I had the same problem, even down to cleaning the carb multiple times. I found that my reverse speed limiter was limiting the rpms even in low or hi. this speed limiter is below the gas tank on the backbone of the frame near the steering head and can be temporarily bypassed by disconnecting the black wire. If your'e problem goes away, you can run it that way or buy a new limiter.
