scrambler starter install
Old May 30, 2007 | 07:40 PM
01vic99's Avatar
Default scrambler starter install
I just got my new starter from a guy on ebay today and it really needs to go in tonight. problem is that it was suppose to come with a gasket but didn't. anyone know why I shouldn't use gasket maker silicon to seal it up. the gasket just keeps water out right?
Old May 31, 2007 | 08:47 PM
outlaw77's Avatar
yes thats all that it does. i had a problem with my starter not working and i tore it apart mainly to see how it worked, and it was full of rust so i cleaned it out a little WD-40 and put it back together and it worked..its got at least another 100 hrs on it now and still working ... but since i got off the subject if i remember right all i used is silicone and no problems... good luck
Old Jun 5, 2007 | 02:02 PM
suds's Avatar
I also got my starter from a guy On ebay, I hope it works great. My questions is for my scram 400 4x4 do I have to emove the front drive shaft to get the starter out? I also need to replace my recoil cord. It looks like I need to remove the front drive shaft to get 1 of the bolts out from the outside of recoil housing. Does anyone know a way I can get around removing the shaft. Is removing the front drive shaft a tough job?
Old Jun 5, 2007 | 06:33 PM
vig's Avatar
vig
You know I had a 98 scrambler, and went through all this, If I remember right you can remove the strter from underneath the machine, lift it up like your doing a wheelie, remove the skid plate and you can gain acccess from there it is a little tight , but can be done.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
raceware
Jul 30, 2015 06:59 AM
ScopeZ_
Jul 28, 2015 01:44 AM
ghost civic
Jul 27, 2015 03:15 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
