GORILLA ROCKER SWITCHES, YES OR NO???
Hi gang, my buddy has a gorilla winch,(the ones on ebay) and he loves it. i have a warn A2000 and have the old style gray turn handle rocker switch. i want to upgrade the switch to a mini rocker switch and gorilla has one way cheaper than the warn one. think these are good quality or should i just pay the $50 for warn?
you cant use the rocker switches w/ the a2000 w/out changing the contacter as well. the switches are way better then the old style grey ***** but i dont beleave you can upgrade unless the whole wiring harness. it would be cheaper to buy another grollia wich on ebay w/ the bigger rating as the upgrade which turns your 2000 into a 2500 lb winch by changing the wiring which comes w/ a new switch and contacter.
the switch i am looking at says this:
Upgrade your winch with the UNIVERSAL SWITCH UPGRADE KIT. Get the latest switch for ATV winches. This weather resistant mini rocker thumb switch kit includes an adjustable handlebar mount, sealed breaker/contactor and all the wiring you need to upgrade your winch system. The switch upgrade kit is compatible with most 12V winch systems. Detailed instructions are included for easy installation. 30 Day Warranty
think it would work now??
