250 carburetor problem
Old Jul 11, 2007 | 02:25 AM
Trailboss725's Avatar
Default 250 carburetor problem
I cannot get the carb to function right, for example it wont spray into the cylinder, i believe its clocked but i ran it through the parts washer and then sprayed air with a compressor through all ports and it was cleaned. but for some reason I can't get gas to come out of the carb and into the cylinder, am i doing something wrong, and i have the manual re-assambly seems to be ok??
Old Jul 11, 2007 | 02:58 AM
itch's Avatar
did you remove and clean the pilot jet?
Old Jul 11, 2007 | 03:11 AM
thats too funny nope i did not its my fault, its too late to go back to my shop and put it together cuz I have the carb here, nope I forgot to clean it and I just did but the main problem is that jet, I have plenty of spark and the compression is good its a brand new setup but it also sat for 12 years but i had it running about a year ago and then it sat in some straight up Florida downpour rain. Well i cleaned it just now and im waiting until after work tomorrow so I can go back and put it together. Let me ask a question, Once the bowl is full of gas what draws it back up, like what makes the pilot jet spray into the cylinder?
Old Jul 11, 2007 | 07:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
take them out and clean them real good. the whole carb should be taken apart and cleaned by removing everything possiable.
Old Jul 11, 2007 | 04:35 PM
So my other question is how does the carb spray the gas like what picks up the gas from the bowl?? I'm guessing the needle.
Old Jul 11, 2007 | 08:17 PM
itch's Avatar
the pilot jet runs off its own pilot circuit which controls idle and 0-1/4 throttle then the negative pressure from the air passing thru from the airbox thru the carb to the reeds sucks fuel thru the main jet controlled by the jet needle that seats in the main jet, when you push/turn the throttle the slide and needle raise and let fuel in the main jet , so the more the throttle opens the more the needle raises exposing the hole in the main jet inturn sucking more fuel.... i think
itch
Old Jul 11, 2007 | 09:56 PM
ok sounds believeable
Old Jul 16, 2007 | 01:23 AM
well problem solved, the pilot jet was completely clogged, now she runs like a dream.
Old Jul 16, 2007 | 01:31 AM
itch's Avatar
sweet,
I'v bought several 2 strokes over the years and it seams most have a dirty pilot jet , bought some real cheap as non running, clean the carb gas it up and go
Old Jul 16, 2007 | 01:40 AM
awesome yeah im not that lucky but i did find a 04 sportsman 700 for like 3000 bucks in orlando, im thinking about driving up and taking a look.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
kelleycully
Sep 15, 2016 02:57 AM
hondarider1234
Jul 21, 2015 11:53 PM
Shifts
14
Jul 13, 2015 08:41 AM
