Polaris Trailblazer Starter will not engage
if you can hear the starter spin when you hit the button but it wont engage it is the bendex/starter drive, it is a seperate piece that engages the flywheel and they go bad quite often, check ebay i think there like 40 bucks on there or like 80 from the stealership
if the starter does not spin when you hit the button its the starter motor itself and most likley needs to be disassembled and inspect brushes , alot of times moisture gets in there and gums them upans they just need to be cleaned and dried
hope this helps,
rich
hope this helps,
rich
bzdok1234
30
02-23-2016 01:55 PM
