bogging
Old Jul 23, 2007 | 07:50 PM
KBOB5's Avatar
Default bogging
I have a 05 sportsman 500 that I've put a k&n filter in and a stiffer clutch spring. I've noticed when i go thru deep mud holes it bogs like it's sucking in water, but when i check evry thing seems dry to me, any suggestions?
Old Jul 23, 2007 | 08:20 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default bogging
when you cahnged the clutch spring did it raise the rpm's. does the k&n have too much oil in it?
Old Jul 23, 2007 | 11:13 PM
Doctorturbo's Avatar
GOT BOOST!
Default bogging
When you put the K&N in did you jet up? If not next time your in the mud, pull the choke on a bit and see if it bogs. Sounds like it needs more fuel to me.
Old Jul 24, 2007 | 12:54 AM
KBOB5's Avatar
Default bogging
yes it raised the rpm's to about 2000, and the filter was preoiled but only a little oil was on it
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
