2005 polaris 400
Old Aug 7, 2007 | 01:57 PM
bellboss's Avatar
Default 2005 polaris 400
It says the engine is running hot, the gas gauage is flashing on and off and the rpm has stopped working. Has any one had this problem?
Old Aug 7, 2007 | 11:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like the modual is going bad. it controlls alot of functions. if the awd is still working then its most likely not the speedo as the problem.
Old Aug 8, 2007 | 10:47 AM
stormyseas's Avatar
ECM - Contact dealer
Old Aug 8, 2007 | 11:04 PM
bellboss's Avatar
today it just cut off. i had to cut the switch off before i could crank it again.
Old Aug 9, 2007 | 07:41 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
cut what switch off??
Old Aug 9, 2007 | 10:36 AM
bellboss's Avatar
When I am riding my polaris 400 - 2005 - the instrument panel goes blank then a few seconds later the engine stops running. In order for me to crank it again I have to cut the switch key back to the off position for it to crank. I can not just turn the switch key where it is in the start position to crank it. It has to go back to the off position then it will crank. It is showing o rpm , the gas gauage blinks on and off but every thing else is working. What will happen if a run it with out a thermostat. It had been running hot but I took the thermostat out and it stopped running hot but I got a price that was 48 dollars for one.
Old Aug 9, 2007 | 11:54 AM
zedzed599's Avatar
Hi, I'm new here and I happen to have a 05 400 that had the same ailment as yours. There was a recall on the ecm for SOME of the 05 400 sportsmans, the recall didn't include mine but none the less my ecm cought on fire ruining the whole wiring harnass, ecm, and stator. I screamed and yelled and put up a fight and polaris ended up paying for the parts. I still had to pay labor. This is a major problem that polaris knows about. Unfortunatly for me , shortly after getting it back I had a bit of an accident and ended up rolling it over. Hope this was helpful.
Old Aug 9, 2007 | 12:06 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Yes , it the Power module, or Electronic control module, same thing, (Sure Power Ind.)
They have circuit breakers in them ...Which when you turn the key off they will re-set!!
I needed to replace mine in my 2006 SP 450 already!!!
Look up the recall list and see it yours in there........if not I guess it will be out of your pocket!!!!
My was under the front headlight mounted to the frame, Black box with fins on it!!(Made in China)
Polaris=U.S.A. ............Don't laugh.....Not made in the U.S.A. but just built!!!!!!
..............Caper..............
Jmuddin284
Jan 19, 2026 07:16 AM
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
steveo612
Jul 11, 2015 08:35 AM
Shifts
Jul 3, 2015 07:59 AM
