My Daughter needs more power
Old Aug 20, 2007 | 08:21 PM
zsebi's Avatar
Default My Daughter needs more power
A governor is a device that automatically controls adjust or governs, say engine RPM. It is a feedback device that automatically makes adjustments. I used a lawn mover because it is a simple, but great example, a portable generator, or a gas operated pressure washer also would be a great examples. These machines has governers to adjust/maintane engine RPM as load increase.
When you fire up your lawn mover and move the throttle from "turtle" to "Rabbit" - as in full speed-, it runs at... say 2500-3500 RPM. Ones you ram the lawnmower into a tall patch of grass the mover's engine doesn't die, instead you hear this deep sound and the engine revs up. The governer automaticly gives it more throttle/gas to maintain optimal engine speed. Same thing on a generator, the governor adjusts throttle setting to keep the engine from stalling.
A transmission is not a governor, it is a transmission. In our case a CVT, or Continuously Variable Transmissions.
Old Aug 20, 2007 | 09:14 PM
crazy1291's Avatar
nice, that makes sense
j.graul84
1) Engine problems..
Nov 6, 2015 08:42 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
Nazz26
Jul 30, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
