2006 Sportsman 700 4 wheel engage problems
Old Oct 2, 2007 | 12:54 PM
02magnum500's Avatar
Gets his share of deer.
Default 2006 Sportsman 700 4 wheel engage problems
I had the same issue on 3 of my machines. But the problem was the oil in the front end was wrong. you need demand drive fluid. Polaris part # 2871654. Just an idea to check first before you tear into it.
Old Oct 2, 2007 | 01:07 PM
galaxie428's Avatar
I haven't changed the fluid in the front yet but that sure would be a lot easier than tearing it down. I also had someone mention to try that first and also see if it is milky. If so, it has water in it and that could be the problem.
I think I have some of the fluid so I may just change all of the fluids, it is probably about time anyway.
Thanks,
Jason
Old Sep 27, 2008 | 10:05 AM
bjb215's Avatar
Default 2006 Sportsman 700 4 wheel engage problems"></title><script src=
BigContryUSA- do you still have the John Deere Part #'s for the roller cage? If so would it be possible to get those from you? Thanks for your help.
Old Sep 30, 2008 | 02:55 PM
BigCountryUSA's Avatar
Here are the parts I ordered:
ROLL CAGE ASSY Part # MIA10667
KIT, ROLL Part # MIA10666
KIT, MINOR REPAIR (Seals) Part # MIA10654
Paid just under $100 for all.
Hope this helps,
BC
Old Sep 30, 2008 | 10:11 PM
  #15
ncriderforks's Avatar
BigCountry, Should any JD dealer be able to get these parts? Is this for there atv line or what are these parts for on a johndeere?
Old Sep 30, 2008 | 10:22 PM
  #16
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
How much are they from Polaris?...........Caper......
Old Oct 1, 2008 | 01:16 AM
  #17
H20's Avatar
H20
Would the diff. be different in the big bore bikes (700/800cc) vs the smaller bikes?
Old Oct 1, 2008 | 11:58 AM
  #18
MECHANIKE's Avatar
i know that the front 4x4 wheel hubs are over $170 as so are the hilliard clutches.so to just get new on one side for a pre clutched diff. your looking at 400+ dollars,that is why i buy them on ebay,i think i'm up to four extra hubs +hilliards, i actually got 1 set for $17 so i can always sell to make a profit.
Old Apr 1, 2009 | 09:55 PM
  #19
awesome's Avatar
hey guys im just wonderin if this would be the same problem for my 2003 600 sportsman it will all of a sudden put the four wheel drive on when i spin the back tires and the switch is off. thanks
TLC
Jun 21, 2015 10:02 AM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
Dave8888
May 2, 2001 06:55 AM
