Trail Blazer 250 Issues
Old Mar 21, 2008 | 12:27 PM
  #21
DoubleOhSam's Avatar
Default Trail Blazer 250 Issues
just wanted to drop-in and tell you guys thanks again for your help. I'm going the "field-testing" route [img]i/expressions/face-icon-small-smile.gif[/img] Make sure chain's tight, tranny's got water-free oil (it does take a little), check steering/suspension etc; and ride it like it's made to be. I will be sure to let you guys know if/when/how anyhting major breaks. Rock on guys.
Old Mar 22, 2008 | 07:28 PM
  #22
vinman18's Avatar
Have you fixed the gas leak problem? mine did the same thing. try tapping on the float bowl with the end of a screwdriver and that didnt work on mine so then i had to take the airbox off and disconect the carb and take the float bowl off then take some carb and choke cleaner and spray everything down with it, that fixed mine. if all else fails than your needles in your float might be bad. hope this helps.
Old Nov 4, 2009 | 03:23 PM
  #23
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums ehw23. Sent you an email with a link.
Old Nov 4, 2009 | 06:41 PM
  #24
polaristrailblazer250's Avatar
i had a fuel leak as well. i just bought a the whole assembly that hooks up to the tank. it was under $20 i think.
Captjay
Jul 23, 2015 12:33 PM
1000gade
Jul 16, 2015 10:48 AM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
