Polaris 250 Trail Blazer
my 1997 trail blazer was just moving and going good the other day. i parked it for a second the put it in gear wen to take off and it moved a little bit then slipped out of gear and wontstay all it does is grind gears can anyone help me?
i had the same problem. All you have to do is drill a hole in the air box and put a hose on it and seal the hose,(block off the stock intake with plastic,glue and duct tape) run the hose to the right front fender and drill a hole and mount it there. the higher level of air will allow the engine to get warmer air so it will be warmer.
THATS MY 2 CENT, IF YOU DONT LIKE IT DONT USE IT!!!!!!!!!!!!!!!!!!
Shifts
14
Jul 13, 2015 08:41 AM
