99 Scrambler 500 prob
Old Dec 4, 2007 | 02:55 PM
saranac1973's Avatar
Default 99 Scrambler 500 prob
Hi everyone. new here. looking for a solution. I have a 99 scrambler 500 4x4. Wont start . Gets spark, gets gas . Just wont turn over and run. I've rebuilt the carb had it running for 3 days . Then a cold front came in , wont start. I've drained the gas 3 times. used gas from diffrent places, ( thinking it was bad gas. Nothing. I use stabil and dry gas each time. Also tested gas in other machines with sucess. Changed the plug , no sucess. The plug comes out wet . Is there a safety shut off iI can test. Someone mentioned to me today about a low oil shut off switch. Any advice would be help full. Also any advice on rebuilding back caliber.
Old Dec 4, 2007 | 06:00 PM
ftwflh's Avatar
I would check the valve settings.Both should be .006
Old Dec 4, 2007 | 06:22 PM
scramblerXrated's Avatar
a compression test wouldnt hurt either.....
X
Old Dec 4, 2007 | 09:06 PM
Compression @ 100% . Valve adjustment I hav'nt checked yet..
Old Dec 7, 2007 | 02:27 PM
Checked valves are @ 006 . Still wont kick over.
Old Dec 7, 2007 | 09:07 PM
ftwflh's Avatar
Take the exhaust loose or off and see what happens
Old Dec 11, 2007 | 02:34 PM
What would taking the exhaust off do..
Old Dec 11, 2007 | 06:29 PM
ftwflh's Avatar
LEt you know if the muffler is stopped up or any other obstructions are in it.
Old Dec 11, 2007 | 07:20 PM
1smokin50's Avatar
If the plug comes out wet, maybe the float is sticking or has a flaw to small to see?? Make sure the choke plunger is closed fully and the same look for flaws in the sealing/seating area... also the carb design has that goofy vacuum system. Make sure all of the diaphrams are good, does the slide move smoothly through it's full operating range? Just some ideas to toss around
Old Dec 29, 2007 | 11:46 PM
Fixed it today. Bad fuel pump...
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
BigCam
Sep 16, 2015 01:53 AM
