Click?
Old Dec 11, 2007 | 04:15 PM
ripley700's Avatar
Default Click?
Hi All-
Probably a dumb question, but when I put my 700 X2 in gear (any gear) as I'm reving up to go it makes a little click just before it moves (like maybe the clutch catching?). Once it starts moving "Katy Bar The Door" no problems. If I rev, it clicks, it moves, If I back off on the gas and the RPMs drop it starts all over again. Is this normal? Thanks for the help in advance!! -Bill-
Old May 20, 2008 | 12:08 AM
atv gooroo's Avatar
Default Click?
I ran across this thread while doing a search for the same thing. I have the same problem as discribed by ripley 700. What is this? I have read that it could possibly be the chain in the tranny. Any opinions? Is it worth the fix, or should I ride it out?
Old May 21, 2008 | 04:17 PM
atv gooroo's Avatar
Default Click?
I hope that it is okay to do this. I just wanted to bump this post one more time.
Old May 21, 2008 | 04:37 PM
ZAKAZIM's Avatar
Default Click?
Glade to see this...Well not glad. I have an 08 X2 700 and was geting this and was thinking I may take it in. It did get less noticable with breakin but sounds just as you discribed
Old May 21, 2008 | 04:40 PM
sprinter10's Avatar
Default Click?
i realy don't think it is clutch it is in teh drive train eather trans or drive shaft slap somewere i. my dads pickup when he puts it in gear moves teh driveshaft a lil untill it finaly starts moving the truck. that could be what is happening i would think that over teh transe but the shifting dogs in teh trans could be warn and allowing slap.
Old May 22, 2008 | 12:26 AM
Deej's Avatar
Default Click?
Absolutely normal condition with all Sportsman I play with. It is slack in the drivetrain being taken up. As stated you will sometimes notice it when moving also - say idling down a hill (slack is taken up the other way), then gas on and you hear/feel it again as the slack is taken up in the forward direction. With slop in the gears and chains in the drivetrain, you will get this. It will never be tight.
Old May 22, 2008 | 10:29 AM
atv gooroo's Avatar
Default Click?
I feel a lot better now that I am not the only one. I was concerned because my my wife as a 05 400 and hers don't do it. I have gotten used to it.
Old May 22, 2008 | 10:36 AM
user493's Avatar
Moto Psycho
Default Click?
My quad doesn't do it but sometimes my truck makes a clunk when it coasts and I give it the gas again. It sounds like the U-joint and drive shaft will fall right off but it's okay.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fordfaithful21
Dec 7, 2015 05:52 PM
kbazzy
Sep 26, 2015 11:26 AM
jsmit116
Sep 18, 2015 10:34 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
