ratteling
Old Dec 26, 2007 | 09:51 PM
800rider's Avatar
Default ratteling
my 08 sportsman 800;s heat shields are rattling, i checked if any bolts were missing or loose, nope, it looks like the shield is hitting part of the frame. is there anything i can put in between the frame and the shield.
Old Dec 26, 2007 | 10:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default ratteling
mine rattles a little too but havent taken the time to find where it is exactly. maybe some pipe insulation would work for ya or can you bend it away from where its hitting.
Old Dec 26, 2007 | 10:03 PM
MECHANIKE's Avatar
Default ratteling
hi, you might put a washer between the frame+ the shield at the mounts,if one don't work then try two,lol.
Old Dec 26, 2007 | 10:21 PM
juttin_15's Avatar
Default ratteling
grind the spot where it contacts
Old Dec 27, 2007 | 09:01 AM
Kerbbirds's Avatar
Default ratteling
I took the shield off and put some spots of high temp silicone under it by all the bolt holes, let it dry overnight and put the shield back on , it works.
dakbee
Dec 30, 2020 11:49 PM
hurryinhoosier
Dec 29, 2008 08:57 PM
16polaris
May 19, 2007 11:20 PM
oaktown22
May 28, 2006 01:20 PM
Stainless
Aug 9, 2004 07:10 PM
