Clutching for a 98 400 sport
Old Dec 27, 2007 | 01:16 PM
wickedzr's Avatar
Default Clutching for a 98 400 sport
I have a 1998 400 sport 2 wheel drive.
It is all stock, Except the rear tires.
It seems like it could use some clutching
I do a lot of work on snowmobiles so I
am a little familiar with clutching.
What can I do to this to wake it up a little.
It engages at a really low rpm,
and doesn't back shift right.
Thanks,
van
Old Dec 27, 2007 | 07:21 PM
ftwflh's Avatar
If you want it aggressive go with an Aaen green primary spring matched to a Aaen blue secondary set at 2-2 with stock weights
Not as aggresive go with a Dalton blk/white primary and either the Aaen blue or HPD violet set at 2-2
Old Dec 27, 2007 | 08:12 PM
onesavage's Avatar
i have the polaris white in the primary,nothing done to the secondary...any recomendations,i just put the white polaris in there because it was in my sportsman before i put the heelclicker in..i would like to go aggressive!!! dont much care about top end , just bottom and mid-range..if i just have to buy some springs that seems cheaper than exhaust right now ..
Old Dec 27, 2007 | 09:56 PM
ftwflh's Avatar
on your trailblazer dont worry about clutching until you get a pipe.Then you must clutch to the pipe.
White spring on a stock TB is decent.But it may be stock on the 400
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
Hack714
Sep 20, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
