trail boss loading up problem[ fuel carb.]
Old Dec 30, 2007 | 12:45 AM
Chase07's Avatar
Default trail boss loading up problem[ fuel carb.]
i have a 87 trail boss 250 that seams to load up when you give it full speed or when you let off the gas.. it will stay running if you give it a very small throtle. or it will die i have cleaned out the carb and had it adjusted fine. will idle . it just recently changed. would it be the air temps causing this any ideas or help would be great thanks Ben
Old Dec 30, 2007 | 09:40 AM
onesavage's Avatar
hmmmmm.
Old Dec 30, 2007 | 10:09 AM
juttin_15's Avatar
have you put any aftermarket parts on it?
Old Dec 30, 2007 | 12:57 PM
eggenz7's Avatar
sounds like the main jet is either too big letting too much fuel in at WOT or the "E" clip on the jet needle is set wrong also letting too much fuel in between 1/2 throttle and WOT. i would start on the jet needle and move the e clip up a notch and see if that helps
Old Dec 30, 2007 | 04:28 PM
Chase07's Avatar
nope no aftermarket parts. heres the story i got the atv from a farmer that had a grandson rebuild it in school rode it a few time then it sat for a few years. replaced the fuel tank,all fuel lines, cleaned the carb,jets and all. new filter and battery. got it to idel great and ran just fine. but after a few weeks and temps being cold it stared to load up or die when it came to idel. im new to this stuff so i wasnt sure if it was the cold weather changing it[like holly carbs do with climite change] thanks
Old Dec 30, 2007 | 04:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if anything the carb would be leaner in the cold weather. are you sure the carb is 100% clean and the float isnt messed up?
Old Dec 30, 2007 | 04:58 PM
Chase07's Avatar
im pertty sure its 100% clean i took the jets out and cleaned them .One was completly pluged could it be maybe the fuel filter might be dirty. maybe some water dirt might hav e work its was losse. dout it [img]i/expressions/face-icon-small-disgusted.gif[/img] it was running and ideling perfect before. we havent rode it to much since the cold weather came
Old Dec 30, 2007 | 07:52 PM
drlang's Avatar
I'd go at the needle and seat for starters. Doc
wildbill59
Jun 20, 2015 02:26 PM
generalpops
Jun 5, 2015 08:23 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
