Starter removal help
Old Jan 2, 2008 | 12:00 PM
Pendragon's Avatar
Default Starter removal help
I have searched the threads, but no match. My sportsman 700 (03) has a bad starter. I need to remove it. I see 2 long small bolts holding it on. Is that all there is to removing it, or is it more in depth than that??? Help please.
BB
Old Jan 2, 2008 | 02:28 PM
SPORTSMAN70003's Avatar
Its pretty simply. Just take your battery cables loose at the battery and then at the starter. Then the 2 bolts holding the starter on then slide it out.l
Old Jun 13, 2008 | 09:54 PM
PatsPolarisPage's Avatar
I have the 2 bolts off and the cable disconnected but it's not coming off. Does it need to be twisted or persuaded?
Old Jun 13, 2008 | 11:00 PM
lobodog3's Avatar
A little WD 40 and a pry bar.
Old Jun 14, 2008 | 12:16 AM
MagnumPO's Avatar
i used a rubber mallet and wooden block on mine. good luck
Old Jun 14, 2008 | 12:53 AM
I got it out, used a pry bar and just tapped it lightly while twisting and pulling. The starter was seized at the bearing, I cleaned it up and greased it good. Turns over easy now. I guess those 2 o-rings don't stop dirt and grime from getting in there. Anyone else have a problem like this?
Thanks for the help guys.
[img]i/expressions/face-icon-small-smile.gif[/img]
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
