sportsman 500
Old Jan 2, 2008 | 08:15 PM
trail hog's Avatar
Default sportsman 500
I have a sportsman 500 and I'm not getting any spark to the plug. Coil and wire both look good. I did a voltage check of the white wire that plugs into the coil, turned the engine over and noticed the voltage came up very slowly and only to about five volts when cranking the engine. Does'nt seem right to me. Could this be a stator problem? If so, how do I go about taking the staor out and is there any way to check it out to see if it's bad? Please help, I'm now shoveling my driveway 'cause I can't use the quad for plowing. Thanks ....Don
Old Jan 2, 2008 | 08:44 PM
RickCJ7's Avatar
More than likely the cdi is bad, did you recently jump start it?
Old Jan 2, 2008 | 08:47 PM
trail hog's Avatar
No jump starting. Brand new battery.
Old Jan 2, 2008 | 08:50 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: trail hog
No jump starting. Brand new battery.</end quote></div>
Did problem start before of after new battery?
trail hog's Avatar
Put in a new battery and about four days later I would ride it, turn it off get right back on and it wouldn't start. Wait a while and it would fire right up. Now it just cranks over and that's it.
Old Jan 2, 2008 | 08:51 PM
trail hog's Avatar
It started after the new battery
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
