Flywheel? Lose it or Lighten it
Old Jan 3, 2008 | 08:43 AM
no694terry's Avatar
Default Flywheel? Lose it or Lighten it
I can see this being a stupid question but is the flywheel needed?
Does it balance the engine, does it work with the stator? I haven't pulled it off yet in my rebuild but I was installin the oil pump eliminator and starter eliminator and from what I see the flywheel is a waste of trottle responce. Are there magnets on it? I cannot see but if I should leave it then I will not pull it off since my stator seems to work fine so I would have no use to remove it unless I want to pick up power.
Old Jan 3, 2008 | 10:25 AM
badazz400's Avatar
yes there are magnets inside your flywheel that spin around your stator causing a electrical magnetic field which helps your motor obtain spark and electrical current.
ritter cycle litens them up you may want to give him a ring.
obtw the flywheel is a must.
Old Jan 3, 2008 | 12:12 PM
no694terry's Avatar
ok flywheel stays, thanks a lot.
I tried emailing Ritter but he didn't get back to me yet, I would like to get a spring kit and the piston and other thing I need for the rebuild off him.
Old Jan 3, 2008 | 01:08 PM
RickRitter's Avatar
Phone me - 618-644-3211 much easier .
http://supremepixels.com/rittercycle/index.php?p=links
Above is a sneak peek at our new website in the works .
Rick
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
