another 4wheel drive doesent work
Old Jan 5, 2008 | 03:31 PM
markshop's Avatar
Default another 4wheel drive doesent work
So i am working on a 1999 sportsman 500 for a friend and when the awd light is on the 4 wd works fine. But when i turn the switch on there seems to be a delay before the light turns on and sometimes it does not turn on at all. I checked the conections and lubed them. wiggled every connection that pertains to it. even checked the connections at the transmission. Could it be a bad switch at tha trans? The same thing happens when i turn the ignition switch to off and then on the awd light sometimes comes back on with a delay and sometimes not at all. But again when the awd light is on everything works fine. Thanks!
Old Jan 5, 2008 | 04:06 PM
miniexcavator's Avatar
I believe that you have to "roll" the machine a little to allow the gears to mesh
Old Jan 5, 2008 | 04:11 PM
markshop's Avatar
I did move the machine back and forth. Doesent make any difference.
Old Jan 6, 2008 | 03:33 PM
markshop's Avatar
Nobody has any ideas what this could be?
Old Jan 13, 2008 | 11:56 AM
jobur's Avatar
Could be the switch. I took mine apart (02 Sporteman 500HO) and found it was full of dust. I cleaned it up, put dialetic grease on , and it has worked fine since.
Old Jan 13, 2008 | 12:04 PM
yamaharap's Avatar
mine had the same problem but it had water i the wiring so i clened it
jayking232003
Dec 4, 2019 09:38 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
Mag500
Feb 13, 2000 11:26 PM
caldwell
Oct 28, 1999 03:30 PM
