what holds the clutch from spinning on the crank?
I would stick with the polaris clutch, go to your dealer they usually have some used older clutches around from when everyone wanted ebs clutches, maybe they will deal.Sounds like the taper is screwed up on your old clutch, did the crank end look ok?
you got to have a broken clutch where it bolts on or something as the crank should be harded steel or something from blocking it from going on all the way. its a basic taper set up and something is messed up it would tighten right up. i would look at both ends carefully before i bought a new clutch. unless the bolt(center clutch bolt) loosend up theres no way for the clutch to back off. imo.
