Sportsman Problem, Any Thoughts
Old Jan 14, 2008 | 09:18 AM
800pocamo's Avatar
Default Sportsman Problem, Any Thoughts
My 07 500EFI will quit running when you come to a stop. Then it is hard to get to crank again. When you turn the key and think it will crank it just dies. It doesn't seem to be struggling to turn over, it just won't start. You let the key go thinking it will turn over and it quits. When it's running it seems fine. No codes and the RPM seems normal. Also, I have noticed that at low speeds it will go dead unless you give it a little gas. The throttle cable is tightly connected and the battery connections are tight. 18 Hours and 25 miles. Any ideas?
Old Jan 14, 2008 | 09:25 AM
RickCJ7's Avatar
Adjust the ETC? electronic throttle cable.
Old Jan 14, 2008 | 09:41 AM
800pocamo's Avatar
Have not tried that yet. Could that be a reason for what I desribed?
Old Jan 14, 2008 | 09:42 AM
JAMIEZ71's Avatar
I agree with Rick, check the ETC. I've had to adjust on mine before, I guess due to cable stretch or something.
Old Jan 14, 2008 | 10:14 AM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 800pocamo
Have not tried that yet. Could that be a reason for what I desribed?</end quote></div>
The throttle should have 1/16-1/8" free play!
Old Jan 14, 2008 | 10:22 AM
smooth1's Avatar
I had the same problem with mine, thanks to others on this forum I finally got it adjusted correctly....
see this thread.....
http://forums.atvconnection.co...id=11&threadid=533262
smooth
Old Jan 14, 2008 | 08:31 PM
800pocamo's Avatar
What should the correct Idle RPM be on the 07 500 EFI. I wonder if mine is to low and that is causing it to go dead when coming to a stop?
Old Jan 15, 2008 | 01:53 AM
CaptainQuint's Avatar
mine was doing much the same. It would die when you quickly lifted off the throttle or got to a low RPM. Terribly annoying and hard on the starter and battery.
I finally adjusted the ETC and it solved it. Took a little trial and error but I got it adjusted just right.
Old Jan 15, 2008 | 08:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
rpms should be around 1150 +- and im guessing as well the etc needs adjusting. got to have a little free play.
skittero
35
Mar 1, 2019 12:39 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Schneider
Jun 4, 2015 11:37 AM
SlyFox
Jun 2, 2000 11:09 PM
c4drm
Jan 2, 2000 08:15 PM
