sp800
Old Mar 15, 2008 | 06:24 PM
bbsq00's Avatar
Default sp800
Just finished installing a switch like that, the earth goes to ground and you will have the light come on when the work lights are on...I wired my third wire to the cig/acc ground wire...
Old Mar 15, 2008 | 06:35 PM
baddboyy21's Avatar
Default sp800
Okay...I was just looking a parts microfiches....Polaris makes an OEM SWITCH-WORKLIGHT,ON/OFF Part #4011074. This is from the 2007 International version of the sportsman. I am thinking that this would be the missing switch on the new sportsman. Am I right? The switch is made to fit in the headlight pod and I am sure it would be water proof. I am thinking about using this switch to get my work lights going.
Old Mar 15, 2008 | 07:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default sp800
if it helps i took a pic. of it today. hook one wire to ground to make the light work.
Old Mar 15, 2008 | 07:11 PM
baddboyy21's Avatar
Default sp800
What did you use to cut the headlight pod? A utility knife?
Old Mar 15, 2008 | 07:30 PM
  #15
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default sp800
a sharp one and heated it so it would melt the paint as well
Old Mar 17, 2008 | 02:51 PM
  #16
badazzpred's Avatar
Default sp800
I got everything to work properly. To make the switch light up I just ran a wire to the ground on the cig/acces option
Thanks for everyones help on here
To cut the plastic I used an exacto hobby knife and a utility knife with brand new blades
Old Mar 17, 2008 | 03:38 PM
  #17
jlhenry1's Avatar
Default sp800
Would you put the rocker switch where the choke goes on the EFI model, or would you want to put it on top of the pod ?
Old Mar 17, 2008 | 05:11 PM
  #18
baddboyy21's Avatar
Default sp800
I am putting my switch on the Pod. Apparently there are cut outs for 4 switches on the back of it.
Aug 21, 2015 01:46 AM
RticKwad
12
Jul 19, 2015 12:22 AM
extremeatvrider
Feb 5, 2006 10:08 PM
CAM650
Sep 6, 2005 10:28 AM
700vtwinman
Apr 27, 2005 05:55 PM
