belt turning
Old Mar 16, 2008 | 09:52 PM
onesavage's Avatar
Default belt turning
cant say for sure but last time i had the cover off it seems that my belt was spinning slowly also..not 100% sure but i do not have the creeping issues or had shifting and i have 2500 hard miles on my lil 400
Old Mar 16, 2008 | 10:05 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: onesavage
cant say for sure but last time i had the cover off it seems that my belt was spinning slowly also..not 100% sure but i do not have the creeping issues or had shifting and i have 2500 hard miles on my lil 400</end quote></div>
If your belt is barely moving because of some friction between the belt and primary that is ok, it should not be spinning with the primary. EBS should not be spinning at all.
Old Mar 16, 2008 | 10:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Mar 16, 2008 | 10:34 PM
RickCJ7's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
exactly!</end quote></div>
What?
if its aligned correctly it won't be turning!
case closed.
Old Mar 16, 2008 | 11:17 PM
  #15
sprinter10's Avatar
both of my atvs turn under idle both primary and secondary not at full speed but they do i thing the lil bit is normal nothing to worry about i had a brand new priamry put on and it still did it shifts fine and my idle isn't up 2 high doen't move at idle in gear i feel that if your trans is easy to spid then it would spin because teh belt is always toching the front even when it is turned off there is always a lil friction there you can't get rid of.
Old Mar 16, 2008 | 11:33 PM
  #16
jokout's Avatar
checked out the Polaris tech videos and it states that the belt should NOT turn at idle...
Old Mar 17, 2008 | 06:50 AM
  #17
wayout's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: jokout
checked out the Polaris tech videos and it states that the belt should NOT turn at idle...</end quote></div>
i would like to see those videos,where did you see them at..
Old Mar 17, 2008 | 07:43 AM
  #18
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Mar 17, 2008 | 09:28 AM
  #19
RickCJ7's Avatar
i dont know for anybody else, but i havent had any shifting issues, no grinding, no other bad things happened and its funny that all brand new polaris sportsmans do the same thing w/ the clutches that i have had, so i guess im not worried about it. my case is closed too!</end quote></div>
Check wayouts previous post,
http://forums.atvconne....co.....adid/538520
</a>
he has a creeping issue,
Old Mar 17, 2008 | 10:16 AM
  #20
TLC's Avatar
TLC
In neutral the belts turns while idling,in gear it does not turn while idling.
