Springs or Lift Kit
Old Apr 1, 2008 | 04:28 PM
SCRAMMYTODD's Avatar
Default Springs or Lift Kit
RTICKWAD Mines feels a lot better at speed and just crawling thru the bush. High speed stability is a lot better with stiffer springs. When you lean into a corner the bike will stay flatter in the corners. My first fast corner when I got my SP had me wishing I kept the Scrambler. Now with the springs my confidence is back. Sidehilling and up and down hills hasn't changed too much. A few time sidehilling the pucker factor was up a bit, but so was everyone else I was riding with.
Old Apr 1, 2008 | 06:39 PM
450 MAN's Avatar
I have a 2006 450 SP my springs are not sagging yet. Would a lift kit give more ground clearance if so what brand and hight would you recommend for my bike
Old Apr 1, 2008 | 09:00 PM
onesavage's Avatar
i bought my lift from www.superatv.com and my springs are highlifter...there are a few threads on makeing you own lift kit for the front...man my 04.5 400 was sagging in 200 miles /a week or so...gave the quad a little atitude adjustment!!
Old Apr 2, 2008 | 10:21 AM
RticKwad's Avatar
Runs Stealth!
ST,
Does your front have to match the back w/r to height? I see you have 1' inch in
the front and 2' in the back, does your new SP springs compensate for the difference
or is that the person weight factor whereby you need more in the back to prevent
the SAG effect (make sense)? (Tech discussion)
Regards,
R'
Old Apr 2, 2008 | 10:24 AM
  #15
stendori's Avatar
Super Quad Patrol
I'm watching you!
is your sagging already or is the back botoming out on full adjustment on the shocks?
Old Apr 2, 2008 | 01:52 PM
  #16
blued's Avatar
Do the spacers lift the atv, if so how much, and can you put more than one spacer per wheel, are these the $15 per pair spacers on the pure polaris website?
Old Apr 2, 2008 | 01:55 PM
  #17
I have the EPI fronts with 1" spacers and a rear 2" lift and it sits pretty well level. I only have the rear springs up one notch and front to back feels pretty well equal as far as how stiff it rides. If I'm planning on riding 2-up or having some gear on the back I'll crank the springs up a bit. Or if I'm just going for mud and I want to keep as much ground clearance as I can. I think I answered your question but if not let me know
Old Apr 2, 2008 | 09:38 PM
  #18
onesavage's Avatar
the rubber spacers are junk imo..i bought a pair and they did nothing..nata,zip...i gave them away
Old Apr 2, 2008 | 11:02 PM
  #19
Hawkman300's Avatar
i dont know about the other ATVs, but the springs on the hawkeye are too stiff as they come. i push down on the back end and let it back up quick and it bounces the back end, not to the point where the wheels come off the gorund or anything, but it bumps when it hits the max travel.
Old Apr 2, 2008 | 11:44 PM
  #20
RticKwad's Avatar
Runs Stealth!
All good info, thanks ST, yea Stendori, I was watching the video of my backend
riding on a straight take off. It really looked like I was sagging a bit in the back.
Even my cousin notices his sits up higher than mine at least it looks that way,
his doesn't have that effect, we are about the same weight and he has the 07' 700.
Just wondering if I would get more benefit in ride quality if I lifted her an inch to
two? Or re-adjusted?
R'
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
Mphillips
Jul 2, 2015 07:20 PM
