polaris 400 engine failure
Old Apr 22, 2008 | 04:08 PM
  #21
conig's Avatar
Default polaris 400 engine failure
I would guess piston skirt they drop alot more often then the rods fail.
Old Apr 22, 2008 | 07:15 PM
  #22
xplorerman's Avatar
yes the pistons dropping skirts is alought more common then rods braking
Old Apr 23, 2008 | 12:41 AM
  #23
Kerbbirds's Avatar
go hpd-inc.com, they have a lot of aftermarket kits for the 400. you might also try hot seat performance, i'm doing there 440 exterminator kit on my explorer 400 i just got from a rancher. ( broken piston skirt) polaris pistons are junk in the 2 strokes. but i'm going from 35 hp to 60 or 70 hp according to hot seats dyno numbers. it's a little pricey, but i have a couple of the things for it already that they recommend.
Old May 14, 2008 | 10:02 AM
  #24
TriCountyTrail's Avatar
It is the probably the counterbalancer.
Check the dipstick behind the carb and see if there is water in there.
The water pump seal leaks then antifreeze gets into the counterbalancer and the bearings fall apart and sieze.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
TJM
Jun 11, 2015 01:28 PM
wildbill59
May 28, 2015 12:05 PM
