Idle in water
Old Apr 28, 2008 | 03:33 PM
atv gooroo's Avatar
Default Idle in water
How come when I put my quad in water it idles down to about 900 or 1000? I am also scared that it will cut off with pipe under water. I ride with alot of hondas and they seem to do real good.
Old Apr 28, 2008 | 03:34 PM
02magnum500's Avatar
Gets his share of deer.
probably the back pressure from the pipe being underwater.
Old Apr 28, 2008 | 03:56 PM
atv gooroo's Avatar
Just wondering what you guys do when you are stuck underwater and you want to go from low to reverse. I am scared to let it idle down for the switch.
Old Apr 28, 2008 | 04:38 PM
If you are stuck underwater and your intake is close to sucking in water, I would shut it off and get winched out. If you are able to back up and the water isn't in danger of going in the intake snorkel, keep the idle up to keep exhaust going out your pipe, and use your left hand to put it in reverse. Not huge idle speed. Just enough to keep the air in the exhaust going in the right direction.
Old Apr 28, 2008 | 05:15 PM
atv gooroo's Avatar
Thanks for the reply, that is how I usually do it. I was just wondering if thats what everyone else does.
Old May 7, 2008 | 04:21 PM
user493's Avatar
Moto Psycho
I just drive through the water and it never gets down to an idle, except one time I had to push my Trailblzer backwards and give it the gas at the same time. It sure sounded funny going blub blub blub blub blub.
Old May 8, 2008 | 05:50 AM
students's Avatar
The same problem was with my sportsman last time, when I needed to left it in the river for 40 minutes. What about making a special snorkel for exhaust? I've seen such snorkels, but I guess they must be made from metal, although I've seen plastic, just need to be sure that it will not get melted.
SDR-II
Sep 29, 2015 01:06 AM
house1
Aug 9, 2015 10:49 PM
ghost civic
Jul 27, 2015 03:15 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
