Running lean
Old Apr 30, 2008 | 09:23 AM
tutiii's Avatar
Default Running lean
I fianlly got my new piston and put my 400 sport back together.
The problem was i was burning the top of the piston.
From other postings the conclusion was that I was running lean.
I cleaned the carb, reset the needle to run richer.
Is there any other reason for this quad running lean.
Where should I look?
Thanks for you help
tutiii
Old Apr 30, 2008 | 11:58 AM
SCRAMBLER500XXX's Avatar
LEAKING CRANK SEAL
Old Apr 30, 2008 | 12:09 PM
tutiii's Avatar
can you tell me where that is?
thanks
tutiii
Old Apr 30, 2008 | 06:58 PM
tbsleeper's Avatar
also go up one size on your main jet to be safe and if it runs to rich then switch back
Old Apr 30, 2008 | 09:37 PM
Doctorturbo's Avatar
GOT BOOST!
The needle change will richen it up very little. Like tbsleeper said, go with a bigger main jet.
Old May 1, 2008 | 02:43 PM
tutiii's Avatar
If the crank seal was bad won't i leak fluid from it?
Old May 1, 2008 | 02:51 PM
tbsleeper's Avatar
dont worry about that that guys been saying that to everyones questions
however it could cause you to run extremely lean....
Old May 1, 2008 | 02:58 PM
tutiii's Avatar
the first time the piston burnt, there was nothing changed. this quad has run perfectly fine for years. just added gas and it went. i never changed anything.
so i'm thinking something had to give way. the question is what?
Frisky2050
Apr 9, 2020 11:19 AM
marioi911
Sport Quads
Jun 30, 2015 12:00 PM
Mphillips
Jun 26, 2015 03:52 PM
hoopduerr
Jun 10, 2015 03:00 PM
dano00
8
Dec 27, 2000 10:10 PM
