new belt problems
Old May 24, 2008 | 07:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default new belt problems
check to see if it dint ruin the fiber washers beside the ebs bushings or if there isnt any stuck cords down in there.
Old May 24, 2008 | 10:30 AM
Ujoint's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: marmon
The belt is also under tension at this time which i know is wrong. </end quote></div>
EBS system belt is always under tension, otherwise the EBS bearing cannot do it's job.
I agree with Stendori - recently I replaced the fiber and brass "washers" (as Polaris calls them) on my primary clutches (both 500 & 700), and the problem was corrected.
Old May 24, 2008 | 12:26 PM
Kerbbirds's Avatar
make sure u put ur spacers behind the secondary clutch, try adding a spacer if u have one and if that doesn't work, take one away.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
trouttracker
Jul 20, 2015 11:54 AM
