can only go half throddle
Old May 18, 2008 | 11:18 AM
damyanke's Avatar
Default can only go half throddle
01 Ranger 6x6 is running ragged. I can only run it about half throddle and after that it pops, spits and spuddlers. It sounds like it is hitting the rev limiter but there is not override button and also it does in forward , high and low and reverse. I have cleaned carb repeatedly and change the spark plug.
Old May 18, 2008 | 04:03 PM
Ujoint's Avatar
I guess I did not realize that the Ranger was built in '01.
If you have the 500 engine, I would suspect the camshaft exhaust lobe has worn down. This is pretty common to happen on the 425/500 engines with some age, especially quicker if Polaris specified 0W40 motor oil is not used.
Old May 19, 2008 | 09:09 PM
damyanke's Avatar
So ...what it the fix or solution for it ...it needs a new camshaft???
Old May 19, 2008 | 10:01 PM
Snortwheeze's Avatar
we have a 96 425 magnum that does the exact same thing taking it in sometime this week to get it looked at.
Old May 20, 2008 | 01:02 AM
jokout's Avatar
Hmmm...before you go tearing the engine down, you may want to check if it has a ETC, I'm not sure where in the throttle linkage it would be but I would guess it has one and this sounds like it may be your problem...may not be but a good place to start before you do something major
Old May 20, 2008 | 07:37 PM
damyanke's Avatar
what is ETC?????
Old May 21, 2008 | 12:52 AM
jokout's Avatar
Electronic throttle control...it is a safety feature...if you have the manual, it should tell you how to adjust it
Beeline08
Nov 11, 2016 04:00 PM
tysonbully
Sep 28, 2015 02:30 AM
bvolks
Sep 13, 2015 12:57 PM
Halffast17
Sep 11, 2015 02:30 PM
John Reed
Sep 9, 2015 03:46 AM
