Hawkey Roller swap: 14 to 12 gm rollers
Old May 31, 2008 | 01:51 PM
user493's Avatar
Moto Psycho
Default Hawkey Roller swap: 14 to 12 gm rollers
<div class="FTQUOTE"><begin quote>Originally posted by: jokout
It is torked to 185 ft. lb. and set with blue Loctite from the factory so it can be a bit stuborn...Put the impact at it's highest setting, and the sudden burst of the impact should break it loose even though it wants to turn, it may take a few tries...also, make sure you are loosening the nut!</end quote></div>
Is it lefty loosey, righty tighty?
Old Jun 2, 2008 | 09:36 PM
Madkins's Avatar
Wow...I can't believe I'm struggling with this....here is the up-date and I still need advice...
I didn't actually try it again until tonight. I can't get the clutch nut to turn....not even a bit.
My impact wrench is rated up to 250lb torque. The air compressor is huge....there is definitely no problem there. So...is this nut torqued higher than 250lb??? Maybe the loctite makes it harder to break?
This is really irritating to be so close to the rollers! I've definitely got it on reverse and the wrench is on the highest setting. Please lend some advice....
Old Jun 2, 2008 | 09:45 PM
TennesseeTider's Avatar
Borrow another torque wrench! Is the belt still on? Leave the belt on and leave it in gear if it is not, that may help some???? I had to let my impact hammer on it for a few seconds.
Old Jun 2, 2008 | 10:58 PM
00XJ's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TennesseeTider
Borrow another torque wrench! Is the belt still on? Leave the belt on and leave it in gear if it is not, that may help some???? I had to let my impact hammer on it for a few seconds.</end quote></div>
Dittos! My impact hammered on it for awhile before the nut came loose. Don't give up as I'm curious as to how the lighter weights work out!
You might try a LITTLE heat on the nut to help break the Loctite loose. Be VERY careful if you do.
  #15
Rickeyparker's Avatar
Impact with a 250 torque should take it off, You will probally need to use a propane torch to heat up the nut and then hit it with the impact, Always remember the rules ---Righty tightie--lefty Loosie, it will come off make sure its in gear and make darn sure the brakes are locked then it will come off.
Old Jun 3, 2008 | 08:39 AM
  #16
Madkins's Avatar
Thanks....I'll give it another try tonight. Just borrowed a 500lb impact wrench from my friend. if that sucker doesn't do it...............
Old Jun 4, 2008 | 09:21 AM
  #17
Madkins's Avatar
Finally had success with this issue. The 500lb impact hammer did the job. Not sure why the 250lb wasn't sufficient. Oh well.
It was raining REALLY hard yesterday afternoon so I couldn't do any good test driving. I'll report back with 0-35mph times (with a pre-modification comparison as well).
Old Jun 4, 2008 | 12:33 PM
  #18
Hawkman300's Avatar
sounds great man, im lookin into doin that mod also. and is there alot of difference between just removing the 2 rollers instead of spending the money on a whole new set?
Old Jun 4, 2008 | 07:17 PM
  #19
Madkins's Avatar
Amazing results! Thanks to everyone for the help. Here is the times I promised:
Pre-Modification: 0-38 mph 11.2 seconds
Now: 0-38 mph 8.1 seconds
Also....that doesn't begin to describe the extra low end power I'm getting. I took it on a hill that I usually struggle with. This thing took it so fast I had to let off the accelerator twice.
Very cheap and fast mod.
My Hawkeye has 24inch Swamp Fox tires which is what started this whole adventure. I would highly recommend a similar config.
Old Jun 4, 2008 | 07:26 PM
  #20
Hawkman300's Avatar
what about top end speed? before and after if u can?
