adjust clutch
Old Jun 22, 2008 | 01:02 AM
fonzythehobo's Avatar
Default adjust clutch
hey i have an 06 sportsman 450 and the clutch isn't grabbing as soon as i would like it to. is there a way to adjust it
Old Jun 22, 2008 | 05:05 PM
user493's Avatar
Moto Psycho
There are lots of clutch mods available, especially springs and weights. Most people would rather have the clutch engage at higher RPMs than lower, because when it barely engages at low RPMs, it heats everything up and breaks the belt.
Old Jun 22, 2008 | 05:31 PM
is there a bolt or something you can tightern or loosen to adjust it. or do you have to replace the springs
Old Jun 22, 2008 | 06:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is no adjustment on the 06' sportsman 450. the clutch should be engaging around17 to 1800 if i remember right. another spring might change the rpm higher or lower(not recommened)if you like, but that only makes it rev higher before the engaging takes place. check to make sure your belt is sitting up about 1/8" above the secondary clutch and that its not burnt the belt.
ghost civic
Jan 15, 2020 07:43 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
