Part Number??
Old Jun 30, 2008 | 12:48 PM
Mexi-Can't's Avatar
Default Part Number??
Anyone know the oil seal part number for a front hub?
Old Jun 30, 2008 | 01:23 PM
Bear1959's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]I have attached a link to a shop by me that has all the Polaris parts list. I have been using this site for my parts no problems to date. the link should get you to the 2002 scrambler, if not back out to their main menu and go from there.
http://www.peakpowersports.ca/fiche_section_detail.asp
Old Jun 30, 2008 | 02:53 PM
Mexi-Can't's Avatar
Sorry to be a pest...The only thing I see on front wheel diagram that says it's a seal sits behind the armature plate. Does anyone know if this it the oil seal that goes inside the inner side of the wheel hub?
Old Jun 30, 2008 | 10:57 PM
You have a strut seal (inside of strut housing) and a hub seal. Hub seal MUST be pressed on or will leak,to replace strut seal,after driveshaft out,use seal puller and bearing installer or large enough socket,Dont knock in strut seal too far! will also leak(look at position of old seal before pulling) needs to cover driveshaft seal ring.
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
