carb problems on 1986 polaris trail boss 250
Old Jul 11, 2008 | 12:04 AM
gussy78's Avatar
Default carb problems on 1986 polaris trail boss 250
Not to hijack your thread but I was interested if you knew the make of the carb.
Old Jul 11, 2008 | 12:28 AM
ftwflh's Avatar
Mikkuni
Old Aug 7, 2008 | 04:13 PM
coal dirt's Avatar
Default carb problems on 1986 polaris trail boss 250"></title><script src=
Hello MetsFan1231,I had the exact same problem with my 86 250 which I am still trying to remedy.It went from running awesome to no power overnight.I have replaced EVERYTHING!!! and had the carb proffesionaly rebuilt TWICE!!! and still didnt do anything.A gentleman on this site reccomended disconnecting the black wire on the rev limiter,I did this today and now it revs a hellin !!! Im excited to see you had the same problem and it was solved with a new rev limiter,This gives me hope!!! Im looking for a new rev limiter Today.I also had a backfiring issue and on my unit found that it was the coil,not enough spark.after I replaced it the backfiring was gone.
Old Aug 17, 2008 | 04:38 PM
800vtwin's Avatar
The exhaust is plugged. Remove the drain bolt and it will run better, try to clean it (hit/ shake / rattle off the bike) or just buy a good aftermarket one.
Old Oct 8, 2018 | 10:23 AM
  #15
Jc_1517's Avatar
I have a Trail boss 250R/ES can't figure out what the year is on it theirs no stickers or anything
Old Oct 8, 2018 | 03:56 PM
  #16
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
The VIN is always stamped into the frame. Finding it is the hard part because they aren't always in the same place, and not always stamped very well. Try looking right in front of the floorboards and the frame rails that go up from there. The 10th digit of the VIN is the year code. Let us know if you find it or not.
ATV Vin Number : Check and Decode Your VIN
Old Oct 9, 2018 | 11:54 AM
  #17
barongan's Avatar
agree with 800vtwin
Old Jan 10, 2019 | 02:07 PM
  #18
jake317's Avatar
88 was the only year for the R/ES
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
PolarisPower500
May 17, 2015 02:28 PM
Matt24
Aug 3, 1999 07:46 PM
