clutching for 500 scrambler
just put a pro circuit pipe on my scrambler and am looking for some clutching advice as to what works best with this pipe . seems to pull alot harder in the bottom end and midrange with this pipe but not sure if there is a whole lot more on the top. i just have a white polaris spring in the primary and stock weights and stock secondary adjusted to 2-2. most of my riding is between 2-6000 ft. i also have a k&n on it and wondering if i should do an airbox mod of any sort. all info appreciated.
If you want a cialed in kit go with either Aaen or HPD or Dalton.You need a tach to do your own clutching to be sure you dont rev too high. For a cheap blast try a Dalton Blk/white and a set of 10MB weights this would be safe without tach.
fordfaithful21
Dec 7, 2015 05:52 PM
cdstang
Aug 31, 2015 07:52 AM
