Transmission Issue - No low range
Old Jul 27, 2008 | 07:50 PM
jharr's Avatar
Default Transmission Issue - No low range
This is on a 2005 Sportsman 700 MV7 with 60 hours on it.
The problem occurred after getting stuck in about 20" of silty mud.
When I put it in Low range, it behaves like it is in neutral. If I hit the trottle it doesn't budge, and I don't smell the belt slipping.
High and reverse work fine. The shifter engages fine, the dash indicates the correct gear. I did get water in the PVT, and drained it prior to getting stuck.
Any suggestions would be appreciated.
Old Jul 27, 2008 | 08:19 PM
Koerbs's Avatar
You probably stripped a shaft or somthing internal, if you don't have good mechanic skills I would bring it on in to the dealer. It sounds fairly serious.
Old Aug 5, 2008 | 01:32 AM
FreddyB.'s Avatar
Sounds to me like the low rang gear slid out of position.
I read somewhere that it has to be moved back into position and tacked in to place so it doesn't move.
Old Aug 12, 2008 | 12:00 PM
jharr's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: FreddyB.
I read somewhere that it has to be moved back into position and tacked in to place so it doesn't move.</end quote></div>
FreddB.
You were right. Just heard back from my mechanic.
The low range gear is press-fit on the input shaft and can slide off.
Option 1. Buy a new input shaft for $278
Option 2. Re-press the gear on the shaft and tack weld it.
Old Aug 12, 2008 | 12:21 PM
kukerdan's Avatar
Are you positive its not the linkage?
but if it was under stress its probably the serious problem
COFatboy
May 2, 2020 12:06 AM
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
Unzzy66
Jul 11, 2015 10:01 PM
bikedad3
Jul 2, 2015 02:15 AM
