trail boss blues
Old Aug 1, 2008 | 09:27 PM
anjinc's Avatar
Default trail boss blues
145 psi compression
timing checked
.006 valve setting
Cleaned carb 1000 times (not easy to get at )
Only runs Good when the air filter and cover is off it runs great with cover off but cove on and all it does is booooooooog
need help as i am about to give up
Old Aug 1, 2008 | 10:27 PM
If only runs good with filter and and air box cover off,sounds like too rich or too much fuel. Replace needle and seat after going through carb? Also check that intake tube on cover not being blocked by tank or foam collar if equipped. Can cut a little sharper angle on tube if in doubt. have seen this before where air tube blocked off air supply. Good luck
Old Aug 1, 2008 | 10:52 PM
scootergptx's Avatar
Supersock
Hired Gun!
Have you had this for a while, or did you just pick it up?
If you just got it, you may want to see what jets they have in the carb, and check the needle settings.
Old Aug 1, 2008 | 11:31 PM
anjinc's Avatar
145 mains needle to nocth or ir's worse 50 piolit
Old Aug 1, 2008 | 11:33 PM
anjinc's Avatar
even with the tube off
i just bought it
but i think i whis ididnt
Shainasmash
May 8, 2017 06:38 PM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
