hawkeye problems finally solved, need some help!!!
Old Aug 4, 2008 | 05:31 PM
Default hawkeye problems finally solved, need some help!!!
Havent really LOOKED,but petcock should be removable and I guess the white piece your talking about is tank filter on petcock? This might be your best way. Just remove and clean while tank drains and can flush out? Will look when get to work!
Old Aug 4, 2008 | 07:12 PM
Hawkman300's Avatar
the fuel petcock is just a plastic on/off valve in the tubing between the tank and the fuel pump and is just removed by taking off the fuel tubing.
the white part that im talking about is the hole in the bottom of the fuel tank that the fuel line attaches to and it is a box and has a fuel nipple that points toward the rear of the atv. it is soft plastic though, so i dont want to try to twist it off if it isnt even meant to be removed and break something.
Old Aug 4, 2008 | 07:40 PM
Thanks for jarring my memory! have not had any fuel problems with hawkeye (JUST REAR DRIVESHAFTS) JMO is to back flush lines and petcock with air to avoid any possible damage. May be some other Hawkeye owners can chip in if have had same problem. Sorry couldn't be any better help! Good luck
skinnyr6
Aug 25, 2023 02:18 AM
toonces
Oct 16, 2019 12:11 PM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
steveo612
Jul 11, 2015 08:35 AM
